AutoCAD Electrical General Discussion
Active Contributor
0 Kudos
Post 1 of 3
Multiple Line Components in Spreadsheet to PLC I/O Utility
285 Views, 2 Replies
10-30-2012 06:31 AM
Does anyone know how to add multiple line components, such as distribution blocks, use the speadsheet to PLC I/O Utility?
Valued Contributor
7 Kudos
Post 2 of 3
Re: Multiple Line Components in Spreadsheet to PLC I/O Utility
10-30-2012 09:03 AM in reply to: Outbound
Just have to add a block file name in the D1BLK, D2BLK, D3BLK... PLC Excel spreadsheet fields. If you need to add a saved circuit file (with blocks, lines, wires, text, etc...) ACADE will need a "*" (star symbol) included in front of the DxBLK file name, in example "*3-wire-analog-circuit.dwg".
Don't forget to try the application tool at: www.racklayout.com . This website generates the Spreadsheet to PLC Utility Excel file automatically.
Active Contributor
0 Kudos
Post 3 of 3
10-30-2012 10:21 AM in reply to: Outbound
EXCELLENT!!!
Can you explain the star("*")?
Thanks for your help!
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
