AutoCAD Electrical General Discussion
Active Member
emarion
Message 1 of 2 (117 Views)
multiple item numbers on a single detail
117 Views, 1 Replies
11-03-2004 08:55 AM
Question,
If I wanted to show the main fuse from the disconnect, I would show in the bom the fuse, the fuseblock etc., How do you show multiple item no. to a single detail on the backplate layout. Do you have to copy multiple blocks and assign each item number or is there a way through the multiple catalog when inserting the fuses, to assign multiple item numbers?
Don't want to make the drawing size larger than needed.
New Member
CraigLiebe
Message 2 of 2 (89 Views)
Re: multiple item numbers on a single detail
01-08-2013 08:30 AM in reply to: emarion
I would also like to know if I can somehow use the fuse part number from the catalog on multiple slots in the fuse holder footprint. I.E. we use a lot if 3 phase fuse holders and when we put the footprint in we need the fuse part number to show on all 3 phases.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
