AutoCAD Electrical Forum
multiple item numbers on a single detail
1 REPLY 1
emarion
296 Views, 1 Reply
Question,
If I wanted to show the main fuse from the disconnect, I would show in the bom the fuse, the fuseblock etc., How do you show multiple item no. to a single detail on the backplate layout. Do you have to copy multiple blocks and assign each item number or is there a way through the multiple catalog when inserting the fuses, to assign multiple item numbers?
Don't want to make the drawing size larger than needed.
1 REPLY 1
in reply to: emarion
I would also like to know if I can somehow use the fuse part number from the catalog on multiple slots in the fuse holder footprint. I.E. we use a lot if 3 phase fuse holders and when we put the footprint in we need the fuse part number to show on all 3 phases.
”Boost
