1. The linkterm should be unique for each terminal. I will look into this
issue and log if necessary. What version of AcadE are you using?
2. On a Copy Circuit the children should update to match the parent if the
parent is within the circuit. If the child's parent is not in the circuit
the child should be reset to the default family code. Make sure the check
box, Don't blank out orphan contacts, is not checked.
Pat Murnen
wrote in message news:5743126@discussion.autodesk.com...
Two questions:
1. If I do a multiple insert of terminals and choose not to show the edit
dialog, the linkterm attribute gets the same value for all the terminals. Is
this normal?? This gives some strange results in the terminal strip editor.
2. When doing a copy circuit the child components do not change their tag
like the parent in the selection. Is there a way around this??
Sven Kloeck
Electrical Network Design
