Hi all,
I see when you add multiple catalog items to a component you can see the data they bring in with the Xdata Editor. Is there any way to bring in other fields from the components database into the Xdata like the User fields?
Bob
xDATA are specifically added and designed for multiple catalog data fields. You can add custom fields using add user attribute feature. These fields can reflect in the reports.
The custom fields can be added using AEXDATA utility with "VIA_WD_XXX" as the required format to the symbol. Use User defined attribute feature and define the the XXX in your block defination. This particular field will get added in the reports.
