Im having trouble with ACADE09 updating more than one block in a title block. In my paper, I have two title blocks, REG (clients) and Contractor (ours). When using Title Block setup, I have "REG,CONTRACTOR" and I can correctly select attributes from both blocks for updating. But when processing update you can see it checking attributes in each block but this is what i get for an attribute called DEG: (the first line I expect)
DEG attribute not found on title block REG
DEG attribute not found on title block Contractor
DEG attribute definetly exists!
