Multi-attribute values are not displayed in the dialog «Insert / Edit Component».
In the dialog «Enhanced Attribute Editor» multi-attribute value is displayed correctly.
In AutoCAD Electrical multiline attributes are not used?
You are absolutely right.
AutoCAD Electrical does not currently support multi-line attributes.
@rhesusminus wrote:You are absolutely right.
Well...it does and it doesn't. The option for making multiline attributes is in the Symbol Builder. But the Edit Component dialog boxes don't really let you make use of them. You can still use the advanced attribute editor when needed.
I've actually been doing this for our terminal block footprints. Rather than having a really long string when there are two wires on a terminal point I wanted them to stack up. I made those attributes multiline and it works. Sort of.
When first inserted from the Terminal Editor or modified, the text comes in as one long string. I've tried using a carriage return as the separator, but it didn't recognize that. So I have to edit them manually. The other nagging problem is that when first inserted or edited, the advanced attribute editor doesn't see them as multiline. After doing a swap block it works fine. Weird, huh?
Only three attachments? What a load of crap. Here is the fourth showing the final edited version. This is a bit of a hassle to get what I want though.
Is the value of a multi-line attribute displayed correctly in the report?
@abtech977 wrote:
To Ms. galashkina
This procedure works for drawing only. Multiline attribute not supported in reports. Do you have any idea how organize multiline attribute for reports?
Unfortunately no
In "Table Generator Setup" select "Define widths" --> Set column widths less then string size -->OK --> Click "Put on Drawing" -->Autocad generates table with multiline text if necessary. See pictures attached. But if you saved report to file, for example to EXCEL, you still need use the WRAP function.
Thank you for your advice!
But this is not what I need.
You have shown how to display a single attribute line in several report lines.
And I need to display an attribute that contains several lines in the report.
