Hello folks. My situation is this: Multi level terminal block, with internal MOV, part no AB 1492-HM2K120. There is a 'line' side and 'load' side. The way the device is wired is, 2 wires to the panel side, 2 wires to the 'outside' (the transient device). What I would like is to be able to show all 4 conenction points, and have them all be associated so I am not doubleing the number of TBs in my bill of material. I can associate the line side (2 conenctions) and the the load side (also 2), but I can't figure out how to associate all 4 so it, in effect, becomes 1 big terminal block. (as an aside, I an showing the MOV, but that is mainly for informational purposes)
ANy help is appreciated.
Thank you
Doug
Doug,
If you can provide us wit ha copy of what you have done so far in a dwg, maybe we can point you in the right direction. What you are asking is definitely doable. Line side/Load side can easily be done with using PIN nnumbers.
