AutoCAD Electrical Forum
Moving Attribute in block makes block disappear..
1 REPLY 1
jagwaran
387 Views, 1 Reply
Hi, I'm using AUD 2009 SP3, Win 7. I have simple block with an arrow and 2 attribute definitions. After placing the block in my drawing, I try to move the attribute text, and the Block (arrow) disappears.
The arrow re-appears if I run REGEN or switch to View port and come back to model space. Though I have AutoRegn enabled, in this case it did not work.
Is this a defect in AUD 2009, or any idea whats wrong with the block.
Thanks in advance for the responses.
Jaga.
1 REPLY 1
TRLitsey
in reply to: jagwaran
Just a thought here.  Could your block be using a 'wipe out' feature?  There may be a chance a chance it is just getting reordered behind the 'wipe out' when you move the attribute.  You could try using a left to right crossing window to select where you think the attribute should be when it disappears.  If something does get selected you will see the grips.  While it is still seleted, try Tools > Drawing Order > Bring to front.  Hope this helps,  Good luck.
Please mark as a solution if this works for you, kudos are always welcome
”Boost
