Hi.
We're using angeled wire-tees. When I use the move circuit function, the wires are "repaired" where the circuit is moved from, but the wire's don't "break" where the circuit is moved to.
The Copy Circuit function works fine.
See the attached drawing where I've copied/moved a curcuit.
Bug?
THL
Trond Hasse LieAutoCAD Electrical and
EPLAN expert
Ctrl Alt ElPlease select "Accept Solution" if this post answers your question. 'Likes' won't hurt either.
