I know that if I want the Manufacturer name information transferred to an object, I can add tag "MFG" to the device. Can I also get the Miscellaneous1 data from the catalog to show in a device? What name would I use? Tried "MISCELLANEOUS1" and "MISC1".
Thanks for any help.
Solved by rhesusminus. Go to Solution.
Thanks THL, I was able to get this to work, but it won't pass the information on the initial insert of the footprint.
Here is the procedure I followed to eventually get the data to pass through:
See attachment for MISC1 configuration.
Any help would be appreciated.
Hi Jmterlap,
You could assign a default Catalog number in the symbol builder for the symbol to use. That would allow the the textvalue to populate right away.
If you just want text in there to see if it is placed right you colud give the attribute some default text. (again this is done in the symbol builder).
If you make the change in the Block editor it will show you the text but it breaks the Symbol. (the ACADE layers are lost).
I hope this helps,
James
My guess is that it doesn't tranfer the sata, as the symbol isn't inserted yet, so there's no MISC1 attribute available.
That's just in that workflow for footprints, so I have no solution for this, if you do it this way.
Also, if the attrbiutes you have in the attached PDF is the ones you use in your footprints, there is something wrong. Footprints use an entirely different set of attributes than schematic components.
So, when using the symbol builder, select
Symbol: Panel Footprint
to get the orrect set of attributes.
The Symbol Builder Attribute Editor palette wil only show the attrbiutes that's a part of the corresponding attribute template file (see the help file).
