I'm completely new to AutoCad electrical, and was wondering if it's possible to create a wiring diagram then bundle it into a module that can be used within another wiring diagram.
What I'm hoping to do is, I work for a small radio station and I'm wanting to create wiring schematics because I've been hired after the fact with there being no diagrams. So what I'm wanting to do is have a wire diagram that shows the office space w/ a "module" for each room and be able to click on the module (room) to see that rooms specific schematics, yet able to "zoom" out to see how each module interacts with each other. Is this possible or am I wishful thinking here and better off creating diagrams for each room and each part of a room?
Solved by rhesusminus. Go to Solution.
Hi.
I would guess that each oom should have it's own sheet in the project. Then, you could have an overview drawing, where each room has been made into a separate symbol, so that you can interconnect the rooms.
If you place a stand-alone cross reference in the overview draing and in the room drawing, you can use the "surf" function to "zoom" into the room maybe?
THL
Excellent suggestion Rhesusminus! I make much use of the stand-alone crossreferences. They are also handy for cross-referencing PLC module splits, and connector splits.
That's what I was actually hoping could happen. Thanks so much for the tip. I guess now I just need to find a good beginners book and start crack'n on it. This is my first meander into AutoCAD so I'm know I'm in for quite the surprise. Any book recommendations?
There are really no books that are better than the built in tutorials. If you really need to kick it into high gear quickly I suggest formal classroom training. One week of training will pay for itself in productivity.
