Yes, there is a tool that can blast through an entire symbol library folder
and scale symbols up or down and/or adjust attribute sizes. Go to the
"Components" pulldown menu > "Symbol Library" > "Modify Symbol Library".
"John Pullen" wrote in message
news:40d3045f$1_1@newsprd01...
> Seems like there used to be a script to run to resize all the blocks...
> Maybe someone else remembers that?
> "TestSubject_US" wrote in message
> news:40d1c739$1_3@newsprd01...
> > If you go to Swap Component, You can swap an old component for a new
> > Component (Option A) or Update Block (Option B). This is the option you
> > want. Click on LIBRARY Swap. In the next Dialog box, Change the
insertion
> > scale to the amount you want the blocks to "grow". Select Project wide
and
> > all blocks in the entire project will be increased by that amount as
long
> as
> > they are in the path listed in this dialog box. If you have some special
> > blocks that you have created and they are not in this path, you will
have
> to
> > rerun this for the different paths. This will increase (or decrease) the
> > size of the symbol and text so this may solve both of your questions.
> > That's it!
> > Robert Hanrahan
> > Weigh Right Automatic Scale Co.
> > ACE user since 1997
> > "teichelberg" wrote in message
> > news:3424901.1087485350496.JavaMail.javamailuser@localhost...
> > > Hi guys, I have a couple of questions.
> > > 1. After working with ACad Electric for several projects, the company
> that
> > I work for has asked me to make a few changes to the component blocks.
> For
> > starters, they want them to be larger. All of my drawings are D size
and
> > are scaled down to 11x17. This is fine, except the components are a tad
> too
> > small, so is there a setting that I could change to increase their size
> > without manually doing it for every component?
> > > 2. The other thing the company has asked me to do is raise the
attribute
> > text above the component more than it is currently. Again, is there a
> > setting that I could change that would universally raise the attributes,
> or
> > would I have to manually edit each one?
