AutoCAD Electrical Forum
Modify Submenu number
3 REPLIES 3
430 Views, 3 Replies
Good morning,
The company i look for is interested in rearanging how the schematic con menu looks. As a result many things have been shifted around from their default submenu folders. When i try to add a circuit to the icon menu it gives me an error saying " Error Cannot display submenu M!9. The subemnu numbder is not defiend...". I opened the icon menu wizard and the user circuit is under submenu 159. How do i redirect autoCAD to that new submenu.
We are using 2014
Jared
3 REPLIES 3
jalger
Hi Jared,
You could try editing the .DAT file directly and change the user circuit section to read " **M19 " it should redirect to the right location (even though your menu number changed.). In Truth I would have left the defaults alone and created your own menu. Then you could create a menu switching command.
The .Dat files are loacted in:
C:\Users\<User Name>\AppData\Roaming\Autodesk\AutoCAD Electrical 20XX\RXX.X\enu\Support (Generic Support path)
*C:\Users\<User Name>\AppData\Roaming\Autodesk\AutoCAD Electrical 2015\R20.0\enu\Support* (2015 support path)
MAKE SURE YOU BACK UP YOU MENU FILE FIRST!!!!!!
Then you can start editing it.
I hope this Helps,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
padredimitry
Thank you!
This solution worked for me!
jalger
in reply to: padredimitry
Glad to hear it worked out.
James Alger
Work:
1tb SSD, 64GB RAM
”Boost
