Does anyone know how to adjust the minimum length when inserting a section of din rail. I have tried adjusting the RAILLENMIN column in the WDDINRL.xls file. However, this did not work. Also, I have tried changing all SLOT** columns to 0 hoping that not displaying slots might help but to no avail. Does anyone have any suggetions?
Joe
Solved by rhesusminus. Go to Solution.
Which of the DIN-rails do you use?
Hi.
I've changed my settings to metric, but the RAILLENMIN does what you want it to do.
Keep in mind that if you have changed the scale-value, that this also affects the RAILLENMIN.
This is my setting for AB 199-DR1:
MFG | CAT | ASSYCODE | DESC | RAILWID | RAILCEN | RAILCEN1 | RAILCEN2 | RAIL2SLOTCEN | RAIL2ENDBASE | RAILLENSTD | SLOTOFS | SLOTCEN2CEN | SLOTLEN | SLOTWID | RAILLENMIN | CHANNEL | CHANNEL | CHANNEL | CHANNEL | CHANNEL | CHANNEL_END | CHANNEL_END | MIN_SHIFT | NCHOLE | BRKT | BRKT_NAME | BRKT_MFG | BRKT_CAT | BRKT_ASMB | CATALOG_TABLE |
AB | 199-DR1 | Symmetrical Rail 35mm x 7.5mm 1m lon | 35 | 25 | 0 | 1000 | 25 | 50 | 13 | 5 | 80 | 17,5 | 12,5 | -12,5 | -17,5 | 17,5 | -17,5 | 150 | dinrail_nc-00a | yes | dinrail_1492-N25 | AB | 1492-N25 | DIN |
If I draw in scale 0.1 (1/10), and try to insert a rail that is shorter then 8, AUtoCAD Electrical tells me that the value is too short, and that it will use 8 instead.
Thank you. The scale-value was the issue. I have reset and it is working as expected now.
I've had the same issue and sent a request on Facebook. Waiting for respond!!🙂
Kind Regards,
Arman
Thank you so much for your reply, my problem is solved.
Kind Regards,
Arman
Could you please let me know if I uninstall and reinstall my AutoCAD Electrical , will I lose my projects I have done. I mean is it dangerous?
Before I came to the company it was installed on "C Drive", but I was told I have to work on another "Drive". Can I bring all stuff to the new one?
Kind Regards,
Arman
