AutoCAD Electrical General Discussion
Valued Contributor
0 Kudos
Post 1 of 4
Migration Utility
673 Views, 3 Replies
09-05-2012 01:53 AM
Can someone help me with the Migration utility.  We have two AE2013 users. I want to update one users menus/catalogue lookup/components etc from those contained on my own PC.  Its migration utility shows no path data or anything, although the PC can browse to my PC over our network.  Is there a simple solution, or am I missing somthing.
The one way will be to modify the wd.env file stored on that computer to point it to the files stored on yours. Even better will be to copy them on a server and make modify the wd.env on all PCs to point them to the new location (network speed might affect performance). The wd.env file in Windows 7 is located here: C:\Users\UserName\Documents\Acade 2013\AeData (if not Windows 7 do a search and you will locate it). Inside this wd.env files are lines for the catalog locations, libraries, menus, etc. For instance your original wd.env file will have this line:
WD_LIB,%SL_DIR%/jic125;%SL_DIR%/jic125/1-;%SL_DIR%/pneu_iso125;%SL_DIR%/pid;%SL_DIR%/hyd_iso125, schem, 1-line, and pneumatic/pid/hydraulic default paths
You will need to modify it to the new locations, something like this:
WD_LIB,Y:/Path/Libs/jic125;Y:/Path/Libs/McRae;Y:\Path\Libs\Panel_External_Faceplates;Y:/Path/Libs/pneu_iso125;Y:/Path/Libs/pid;Y:/Path/Libs/hyd_iso125, schem, 1-line, and pneumatic/pid/hydraulic default paths
If you need to transfer toolbars/ribbon customizations from one computer to another one:
  1. if you are running the same version then you can use the Migration Utility,
  2. if not then you will have to save the CUI from the PC you want to copy from and open it in the Customize User Interface and drag&drop them (see the attached picture for the command and interface).
Good luck!
Active Contributor
3 Kudos
Post 2 of 4
Re: Migration Utility
09-05-2012 03:45 AM in reply to: JMARSHALL1249
WD_LIB,Y:/Path/Libs/jic125;Y:/Path/Libs/McRae;Y:\Path\Libs\Panel_External_Faceplates;Y:/Path/Libs/pneu_iso125;Y:/Path/Libs/pid;Y:/Path/Libs/hyd_iso125schem, 1-line, and pneumatic/pid/hydraulic default paths
Good luck!
Valued Contributor
0 Kudos
Post 3 of 4
09-05-2012 05:27 AM in reply to: JMARSHALL1249
Thats fantastic. Thank you.
Valued Contributor
2 Kudos
Post 4 of 4
10-28-2014 10:07 AM in reply to: stefan.stamate
I want to 'migrate' my old customized Icon Menu (ACE 2014) to  the new Icon Menu (ACE 2015). I really wish this migration to a new version of the software didn't make me feel like I needed to become a programmer. It would be a much welcomed improvement (I suspect for more users than myself), if there was a migration utility to actually handle all of this 'automatically'. I could then, more quickly get back to what I do best. Am I missing something?
Apologies for the growl.
Rick Yoerger
AutoCAD Electrical 2015
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
