Can someone help me?? I have created several custom PLC's using the PLC database file editor in AutoCAD Electrical 2013 and would like to migrate those to AutoCAD Electrical 2014. I have tried using the migration utility without any success. I do not want to recreate them any help would be greatly appreciated.
THANK YOU
Mark
The database file you need to copy is ACE_PLC.MDB.
This can be found C:Users\*****\Documents\Acad20**\***\. Try a File Explorer Search, sometimes the \Acad20**\ directory will be hidden. Make sure you bakup the database file above on a thumb or network drive just in case your harddrive poops out. It happens.
I don't have the 2013/2014 version, so I cannot be sure of these newer versions.
Since you are using the Parametric PLC's I suggest trying the following website for creating a PLC IO Utility Spreadsheet: www.racklayout.com
I tried your suggestion to copy the .MDB file over and it did not work. The PLC's I created were not there. I noticed in the search for that file name it was also found in program files also and I copied it there also but still o luck.
Any other idea's anyone?
Thanks for your help Electricman 1, I will try that racklayout.com
