AutoCAD Electrical General Discussion
sonny3g
Message 11 of 12 (134 Views)
Re: MFG01, CAT01
11-19-2012 07:11 AM in reply to: arthivasu
You have to have the part in your lookup database for the BOM routine to find it.  Also, you may want to add a wdblknam attribute to the block.  And finally, you can add text to any attribute in your block from the database by using the TEXTVALUE field and separate the attributes with a ; (ie. DESC1="RELAY, LATCH";RATING25="4").
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
testsubject
Message 12 of 12 (129 Views)
Re: MFG01, CAT01
11-19-2012 07:33 AM in reply to: sonny3g
For the TEXTVALUE to work properly, the attributes have to already exist in the symbol itself. I use this function a  lot when I create the panel first and then the schematic. In many of my footprints, I have added the following attributes;
MFG01, CAT01, MFG02, CAT02,  and then added those items to the TEXTVALUE field.
Bob Hanrahan
Ace User since 1998
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
