AutoCAD Electrical Forum
Merge Toolbars
2 REPLIES 2
230 Views, 2 Replies
Merge Toolbars
Good Morning....
Does anyone know a simple way to merge the items from several different
Autocad Electrical Toolbars. I want to creat one large floating toolbar with
my most used items. I have tried like hell to create a new toolbar but can
not figure out how to drag and drop buttons from other toolbars
Thanks for the help
Jim Colacino
2 REPLIES 2
If you are using ACE 2005......click on "VIEW" on your top menu and select "TOOLBARS" . This will allow you to select different commands to establish a new toolbar or a new tool palette. Hope this helps......
Marty
You can also create brand new custom toolbars using the buttons and commands from existing toolbars. The methods depend on which version of ACE you are using. If its 2006, you will use the new CUI editor. There are a couple of white papers on the Autodesk website that contain brief lessons and instructions. If you are using an older version of the command you will use the Customize command to create a new toolbar. In either case, once the toolbar is creating, it's a relatively easy step to drag the commands onto the new toolbar.
”Boost
