There is another way to do this.
Its been a while since I last configured ACE for an employer to do this, so bear with me and maybe someone else can fill in the blank here.
I seem to recall that there is a place in the project and/or template *.wdp mdb file where the rung number can be hard coded in.
This gives a different result than changing the drawing properties, where the drawing properties setting will use SS-NNN format or SSNNN format, it will actually start the NNN number with the sheet number. THe benefit of this is that you end up with a smaller character count footprint for the rung number.
To clarify, the NNN number is the only number used, but it starts with the sheet number, for example:
Normally rung 100 on sheet 5 would be 5-100 or 5100 using the drawing properties.
What I am talking about is starting the NNN number with the sheet number, so the NNN would actually be just 500.
Anyone familiar with a cheatsheet on the wdp line settings help me out or share this content?
BUMP
I think what he is talking about is changing a variable so that the PROJECT-WIDE update/renumber ladder references based on the sheet value rather than entering it in each sheet manually.
See screenshot for what is not working as expected.
One of the ?[x] variables in the WDP file can be changed to make this work as a project-wide retag of ladders, I just cannot remember which one.
