We have been adding parts to footprint drawings for many weeks and have been using the Mark Existing feature in the schematic listing to know what are the new parts and what are already added. I just tried today and it is not working. I did an AEREBUILDDB but still not luck. Any suggestions on what to look for? The Installation and Location codes are identical for the devices and the Surfer shows that they are "Linked".
Any help is appreciated.
Try these steps...
1 Shut down ACADE.
2 Find the <Project Name>.mdb database file (make sure it is the MDB file) and delete it.
3 Start ACADE and the project database will be rebuilt.
4 Try the Mark existing on the schematic list again.
Sometimes the project database gets out of step with the project and even an internal project rebuild won't fix it, but deleting the file and then recreating it from the dwgs does.
Regards Brad
Brad Coleman, Electrical Draftsman
Some devices, with "TRMS" (terminal - not sure if there are more, probably distribution blocks etc also) family codes in the panel layout block definition will not show as "existing" when you rebuild the schematic list. For example, the Allen Bradly Fuse Holder 1492-H5 is treated like a terminal, not a fuse holder. It will show up when used in a terminal plan though. I prefer to drop them in individually/manually rather than have them appended to a terminal strip ID.
