Hi All,
Let me first say that im not an AutoCAD user at all, but im trying to do the following:
I have dxf file of an electrical board with all its elements (cb's terminals, mechanics etc...) for each element ( a block) the name is written in a little label placed above the block, and this text label is very important for me, inorder to do some integration and mapping of this dxf to another CAD application i work with.
what I need urgently, is a method to automatically make ALL the labels of each block in this dxf, a block attribute, so i can recognize it in another application. for instance, the AutoCAD operation : AELINKDESC is working ok manually, but the cons are: 1st - i only do it manually 2nd - it ties the text to one of 3 available attributes (DESC1,DESC2,DESC3) and i need all the text to be tied to a single attribute.
I hope there's someone here who can help me.
THANKS ALOT!
Noam
If you can post a drawing here, or mail one to me (thl@ctrlaltel.com), I'll have a look to see if done can be done with a quick VBA routine.
There are a couple of BIG challenges you are going to run into with doing this automatically.
How do you define what text becomes what attribute?
What text goes with what block?
There is a manual function to change text to a block attribute, but you have to select the text, the block you wish to tie it to and then select what attribute you wish it to become. This tool is located under the drop down menu Components->Attributes->Convert Text to Attribute Definitions.
Then you do the same for the next line of text.
It won't be easy to program and there are sure to be blocks that have text added to them that should have gone to another block or another attribute.
Regards Brad
Brad Coleman, Electrical Draftsman
