AutoCAD Electrical Forum
LSP Routine
2 REPLIES 2
278 Views, 2 Replies
LSP Routine
Nate:
I have been using your milnum_plc.lsp routine that you had posted on your blog. I am finding it works great for 2 components (without 1 being a PLC) but I have a question. If you look at my attached PDF you will see it listing the component on the RIGHT first, I would like to see it list components from left to right. What controls that?? ( I am not a LISPER) But other than that.....it is SWEET. and would like to see it added as a standard wire labeling option.
Marty
2 REPLIES 2
oops here is my PDF
Marty
Try this modified version. It looks at the XY coordinates of the two wire
connection points and reverses the order if it appears that the second
connection point is to the left or above the first.
Nate.
wrote in message news:5253532@discussion.autodesk.com...
Nate:
Marty
”Boost
