AutoCAD Electrical Forum
Lost plot style manager
2 REPLIES 2
johnq
555 Views, 2 Replies
Hi folks
This morning I had a FATAL ERROR,  nothing unusual about that as this often happens when closing files.
This time it happened when I was updateing a BoM.
Reboot was OK. All seemed OK and all I lost was a few devices on a drawing.
Later I came to print and discovered I have lost the "plot style manager" in the "format" ribbon menue.
I knew this as ACE reported that there was a problem witht the printer.
How do I get it back?  (the plot style manager)
I have lost the .pc3 file for the printer and I can't recreate it.   ACAD reports that i am writing to and illegal file.
I use CutePDF to create my PDF files and I have also lost the .pc3 file.
These two .pcs files are usually in the printer menue of ACE where I select which printer I wish to print from.
I can print previously save PDF drawings correctly.
Hope some one can steer me in the righ direction.
Cheers  John Quigley
2 REPLIES 2
algerj
in reply to: johnq
This is an interesting issue...
Have you lost the ability to invoke the plot manager from the big "A" as well?
(Big "A" > Print > Manage plotters)
Can you check in the CUI to see if you still have ACAD as a partial load in your ACADE workspace.
(Look for ACAD in the Partial Customization Files expandable tree)
I have seen this before in an older version of the product (ACADE 2007), it would lose the partial file that allowed Regular AutoCAD commands to run. (usually on a fatal crash during startup).
Try reloading the partial file.
Let me know,
James Alger
SolidCAD
johnq
in reply to: algerj
Hi James
Thanks againg for your time to reply to my questions.
I have been partially stupid.   The Plot style manager is greyed out when I look for it under the Format button.
I forgot to look for it under the file botton.
My other problems have been solved with the reload.
Cheers  jq
”Boost
