AutoCAD Electrical General Discussion
0 Kudos
Post 1 of 2
lookup error!!
107 Views, 1 Replies
12-08-2012 07:39 PM
     Sometimes when I want to lookup the component's catalog the error message will be showed,I have to restart the software,when restart the software again,the function work normally~
     So,anyone know why?
Valued Contributor
6 Kudos
Post 2 of 2
Re: lookup error!!
12-09-2012 06:00 PM in reply to: bilong.li
Normally, this is just a message to info you that this component family table is not available in your current default catalog Database. But once you click on OK, and create the family table or componet specific table it should be fine.
Maybe you can open the default_cat.mdb and check if it is there anot.
Not sure what version you are using.
Thanks.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
