AutoCAD Electrical Forum
lookup error!!
1 REPLY 1
bilong.li
255 Views, 1 Reply
lookup error!!
     Sometimes when I want to lookup the component's catalog the error message will be showed,I have to restart the software,when restart the software again,the function work normally~
     So,anyone know why?
1 REPLY 1
lionSG
in reply to: bilong.li
Normally, this is just a message to info you that this component family table is not available in your current default catalog Database. But once you click on OK, and create the family table or componet specific table it should be fine.
Maybe you can open the default_cat.mdb and check if it is there anot.
Not sure what version you are using.
Thanks.
”Boost
