AutoCAD Electrical General Discussion
Dan.M
Message 1 of 6 (245 Views)
Looking for this block
245 Views, 5 Replies
02-17-2013 06:49 AM
Hello
Wich block in Electrical does this connection ?
I mean to tag SW2
Dan
johnq
Message 2 of 6 (219 Views)
Re: Looking for this block
02-17-2013 02:10 PM in reply to: Dan.M
Hi Dan
I am on ACE2012  and in it  WDDOT  is the block for a DOT.
To find it I drew two wires which crossed and put at the junction a DOT from the icon Menue.
Double left clock on the DOT and the list comes up and WDDOT block name should be highlighted.
Hope this is what you want and helps.
As in many Elecrtrical programs it is a seriesof concentric circles.  A solid dot has more bytes.
Cheers  jq
johnq
Message 3 of 6 (209 Views)
02-17-2013 07:10 PM in reply to: johnq
Hi
I have just reread your question and To answer the real question you ned to include the drawing.
Did you draw the diagram?
Cheers  jq
Icemanau
Message 4 of 6 (200 Views)
02-17-2013 08:16 PM in reply to: Dan.M
Which block do you mean....
The Capacitor (HCA1 or VCA1 or HCA1EL or VCA1EL located under Miscellaneous, Electronics)
The Switch (closest I could get is HDS11Q89 or VDS11Q89 located under Breakers/Disconnects)
The wire Junction (WDDOT as someone has already replied with)
The H or V indicate the orientation of the component. H for Horizontal and V for Vertical.
Go to the Insert component tool and look in the sections I gave for the location. Using this tool will select the correct orientation depending on the wire you insert the block into.
Note that I listed both the plain and the Electrolytic versions of the capacitor.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Dan.M
Message 5 of 6 (176 Views)
02-18-2013 06:39 AM in reply to: Icemanau
Hello all,
I meant to the block with the red lines and 4 circles.
Dan
Dan.M
Message 6 of 6 (175 Views)
02-18-2013 06:41 AM in reply to: Icemanau
it is a switch of some kind and the wires can connect to other point whenever I choose to.
Dan
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
