I discussed this issue in an email thread with Thomc and here is a summary
of what we found out. First, when he attempted to test the connection using
the UDL file that was provided in an earlier post, he received an error that
the provider could not be found. He checked the Provider tab in the Data
Link Properties dialog and sure enough the "Microsoft Jet 4.0 OLE DB
Provider" was missing. We determined that he had the correct files
installed, just that one or more of them had not been registered. I had him
register msjetoledb40.dll and msjet40.dll. Once those DLLs were regestered
he was able to load the PLC database without any problems.
Mike
"Mike Spitzer (Autodesk)" wrote in
message news:4861594@discussion.autodesk.com...
Thomc,
I have attached a zip file that contains a UDL file with the basic settings
that we use to connect to the PLC database. Please download the attachment,
unzip it and and double click on the "Test ACE_PLC.udl" file to bring up the
Data Link Properties dialog. Once the dialog is up, do the following:
1. Make sure that the Connection tab is active.
2. In the "Select or enter a database name:" type in or browse to your
ace_plc.mdb file. Do not change any of the other se
ttings.
3. Now click on the Test Connection button, to see if it connects properly,
and report back the results of the test. You can post the results or if you
prefer, you can send them to me personally at mike.spitzer@autodesk.com and
we can try to work through this using direct email.
Mike
wrote in message news:4859923@discussion.autodesk.com...
AutoCAD electrical 2005 loads the full modules with no problem, but when I
selected parameter units, it gives me an error sayi
ng: unable to load plc
database ad gives the path to the database. I have checked and the path is
correct, the database exists, the file is not marked as private or anything
as such. I have tried disabling antivirus and firewalls in case these might
be the problem. It has been reinstalled and that didn't help. Please advise
to what might be stopping the AutoCAD from loading this database.
