AutoCAD Electrical Forum
_LISTBOX_DEF table
4 REPLIES 4
goldfinger
305 Views, 4 Replies
_LISTBOX_DEF table
I’m trying to use the _LISTBOX_DEF table in the default_cat.mdb file and it does not seem to work. Is anyone using this?
Help Ref: Chapter 11 Catalog Database Table Structure
My Table
TABLENAME MFG LIST1 LIST2 RECNUM
AH FEDERAL 100DB 120V 1
Thank you in advance
4 REPLIES 4
goldfinger
in reply to: goldfinger
Found the problem.
field names LIST1, LIST2 should be LIST2, LIST3
"goldfinger" wrote in message news:12354757.1079626936059.JavaMail.jive@jiveforum1... > Found the problem. > field names LIST1, LIST2 should be LIST2, LIST3
Are you saying there's a problem in the doc or just a misread of the doc? Nate. "goldfinger" wrote in message news:12354757.1079626936059.JavaMail.jive@jiveforum1... > Found the problem. > field names LIST1, LIST2 should be LIST2, LIST3
goldfinger
The doc is correct
I need glasses
”Boost
