AutoCAD Electrical Forum
Lisp routine wd_import_scratch_mdb_doit
0 REPLIES 0
Message 1 of 1
417 Views, 0 Replies
I would like to import infomation from a table in the scratch mdb which is not on the list of table choices when you execute AEIMPORTDB (from the menu or icon). I found the wd_import_scratch_mdb_doit routine in the documentation and wrote the following code to test it:
;;; **** This code assumes the current drawing is the first drawing in the active project  ****
;;; **** and reads data only from the table BLOCK_ATTR  ****
(defun c:db_upd ( / fnam tbl_lst hdl idx)
      (setq tbl_lst (list "BLOCK_ATTR"))
        (setq idx "1")
  (setq fnam (c:wd_mdb_get_proj_scratch_dbnam nil)) ; "nil"=get current proj mdb file name
  (setq hdl (wd_mdb_GetHandle 1)) ; get next handle, MDB format
      (if hdl
        (progn
          (if (wd_mdb_Open hdl fnam) ; open current project's mdb file
            (progn
              ; import new data from scratch db fnam = scratch db name, idx=dwg index within prj,
              ; tbl_lst= a list of tables from which to import data
             (c:wd_import_scratch_mdb_doit fnam idx tbl_lst 0)
      (wd_mdb_Close hdl)
      (setq hdl nil)
This code did not error but reports no mismatches found even though I have changed the scratch db. Is there another step to force the new entries in the scratch db into my drawing?
0 REPLIES 0
”Boost
