style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<dougmcalexander> wrote in messageThat
href="news:6092537@discussion.autodesk.com">news:6092537@discussion.autodesk.com...
is done via the peer-to-peer relationship feature. Go to Electrical Helps and
click on Advanced Productivity. The solenoid and valve each have a WDTAGALT
attribute. You can see this from the Insert/Edit Component dialog if you click
Show/Edit Miscellaneous near bottom center. Set the WDTAGALT value of the
solenoid to the tag assignment of the valve. Edit the valve and set it's
WDTAGALT value to the assignment of the solenoid. That's it. They will be
bi-directionally maintained and viewed as one component on the BOM. That is
the short sweet answer. The help system goes into greater detail. Screen shot
attached.
I have the same issue: One pneumatic valve with two solenoids. Have you figured this out?
One valve with two solenoids is tricky. I have never liked the valves from the pneumatic library that Autodesk supplied, so I redraw them. In this situation I don't keep the solenoid actuator as part of the valve symbol anymore. I'll let the software give the valve a tag. Then I made separate solenoid actuators (but the library does include them if they're satisfactory to you) and place them on the sides of the valve, and those are the ones I link back to the solenoids in the electrical schematics.
How can this be an issue in the year 2023? It works perfectly in competing software...
