It sounds to me like you have two solenoids within one valve. One way to document this by inserting a solenoid symbol off of each PLC output and let each have a unique tag. But only enter BOM data in one and only link one to the pneumatic drawing via the WDTAGALT attribute.
Another option is to indeed create a second SOL schematic symbol named, HSV2 and change the TAG1 attribute name to TAG2. Just copy the HSV1 and rename it to HSV2 and change the TAG1 to TAG2. Insert the HSV1 first. Then insert HSV2 and pick HSV1 when prompted for parent/sibling. From the edit screen of the parent, HSV1, click Show/Edit Misc. and enter the valve TAG from the pneumatic drawing into WDTAGALT. Go to the pneumatic drawing and edit the valve and enter the schematic TAG of the HSV1 as the WDTAGALT attribute value. I just tested it and it works. I will attach an HSV2 I created in my JIC125 library folder. If your solenoids are vertical, you may need to create a VSV2.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
