AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Linking Schematic Components to Specific MFG/CAT/ASSEMBLYCODE
1 REPLY 1
crosby.109
463 Views, 1 Reply
I was wondering if there was a way to have the User pull a default schematic component down, do a Lookup in that section and if he chooses a specific entry, have the schematic symbol know to change accordingly.
Thanks!
1 REPLY 1
You can accomplish something similar using the Equipment List option.  Search Help for details.  This is handy when you have been given a spreadsheet of part numbers that must be used.  It works in conjunction with the Schematic_Lookup.mdb.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
