The wire could connect to two devices so how would the wire know which
component to get its tag from? Maybe I'm not understanding your question.
A wire number is a potential number or electrical "node" number, useful for
troubleshooting or tracing a circuit voltage or signal.
If you are seeking to create a label for each end of your wire, which
depicts the exact component tag and terminal the wire connects to, you
should be able to get this by generating a schematic from/to report and
filtering to only the CMP:PIN1 and CMP:PIN2 fields. You click change report
format remove all from the right window then add only the CMP:PIN1 and
CMP:PIN2 fields. Click the Save As button and save your special report as
something like DIN wire markers or IEC wire markers, etc. This is a common
way to mark wires in Europe. I worked for a German company for 12 years and
that is how we marked them. See the attached screen shot example. This
report can exported as Excel, ASCII, etc. and sent to your wire marker
printing software application.
wrote in message news:5743017@discussion.autodesk.com...
i'm having some problem customizing my ACE2008. Is it possible for me to
have the wire number referenced to the component tag? I don't see any option
for me to do such thing. Anybody have an idea?
-akram
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
