AutoCAD Electrical Forum
Learning to use AutoCAD Electrical
4 REPLIES 4
cadmantom
542 Views, 4 Replies
Greetings to all:
I have used 2D AutoCAD for many years (starting with DOS-based Release 10) and have been using Inventor (oh what a difference a parametric database makes!) for about 2 years.
I am now learning AutoCAD Electrical 2013 and am going through the tutorial withing ACADE.
* There is a method to report problems within the tutorial but apparently not a way to receive feedback.
* I know that all of you are experienced ACADE users (I will get there as well).
* I hope that you don't mind if I ask some elementary questions in the meantime.
I am using your ACADE Tutorial
* DE_TITLE_BORDER.DWG is not in the location specified in the tutorial:
•Windows 7: Users\{username}\Documents\Acade {version}\Aedata\Proj\Aegs
Can someone help me find this file?
CADManTom
4 REPLIES 4
Tee.Dee
in reply to: cadmantom
I think the path you are looking in is slightly incorrect.  Try looking here:
Users\{username}\Documents\Acade {version}\AeData\Tutorial\Aegs\Title Block
Tim.
cadmantom
in reply to: Tee.Dee
Thanks, this works.
* Appreciate your help.
CADManTom
dougmcalexander
You can learn the basics of the software from the built-in turorials. Also, almost every dialog has a Help button that takes you directly to the Help topic related to functions on that dialog. The help system is quite good. For more help, visit my web site at: www.ecadconsultant.com
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
If you haven't seen it yet, there is a recent thread in which I included some links to learning resources, including Doug's site. You can see that thread here.
Welcome to ACADE!
Jim
Jim Seefeldt
Electrical Engineering Technician
”Boost
