AutoCAD Electrical Forum
Layers don't lock on Layer Isolate AutoCAD Electrical 2011
2 REPLIES 2
aeiken
585 Views, 2 Replies
When I use Layer Isolate to isolate a layer and then try to window around it to change layers for example, any items that are in the window, isolated or not, are selected. Is there a system variable that can be set to make Layer Isolate work as it did in previous versions of AutoCAD Electrical where only isolated layers will be selected and the other layers will be frozen or locked?
Ken
2 REPLIES 2
in reply to: aeiken
When you go into the layer isolate command, hit S for settings.  You can lock and fade the layers from there.
aeiken
in reply to: aeiken
Thanks! That was just the fix I needed! Ken Miller Instrumentation and Controls AEI | AFFILIATED ENGINEERS, INC. 5802 Research Park Boulevard | Madison, WI 53719 P: 608.441.6665 | F: 608.238.2614 kmiller@aeieng.com | www.aeieng.com
”Boost
