KC, regarding number 1, I think you may be going outside the scope of
AcadE. Remember this is not a drafting tool allowing us to get away with
anything. It just so happens that it is integrated into the greatest
drafting engine there is. I wish the name wasn't AutoCAD Electrical though
because so many companies send drafters to my training classes, assuming
that it is a drafting tool. I often wind up explaining design principles as
a I teach, because I get such questions as, "how did you know you needed a
fuse there? How did you know what size and type? How did you know what size
and color of wire to use?"
Almost everywhere I go, people coming from plain vanilla AutoCAD, where
there are no rules, try to make AcadE play by their past rules, which are
mostly outdated or made up, not adhering to any established standard. AcadE
however, follows established electrical standards and thus must have some
absolutes with which to work against. That being said, the default layer
for symbols is SYMS. I have never found a need to change that. If you wish
you can change the layer names to something custom by clicking the Layer
button on the Drawing Format tab of Drawing Properties. But to mass change a
symbol's layer assignment is biting off a bit more. You can probably do it
with the combination of a script and a lisp routine. However I have been
using the program since 1997 and I just design with it; I try to not
reconfigure it too much, especially since I teach it as well, and it would
confuse my students to see mine look and act so different.
As for number 2, I cannot say that I have seen such a phenomenon. If you
insert a relay coil that has an entry in the pin list database, once you
perform a lookup and assign a MFG and CAT, AcadE pulls the pin assignments
in from the database and fills in the coil pins. Then when you later insert
a child contact and associate it to the coil, the first set of available pin
numbers are assigned. If you prefer a different set of pins, you click the
List button and select a different set.
wrote in message news:5992622@discussion.autodesk.com...
Thanks Doug for the help recently, getting there slowly but surely!
I have two current problems that I can't seem to resolve.
1. I need to change all the blocks within my current project to another
layer. Primarly the components, currently they are in 'SYMS' I would like
them on 'MY_LAYER' for example. I have changed them other iin the drawing
and project 'define layers' option and tried to update the blocks within the
drawing. Firstly, they won't update, however, when I insert a new block it
works fine. Secondly, once I have worked around this, is the only way to do
each drawing and update block, or can you do it project wide somehow?
2. From previous posts I have created my own relay pin assignment, which
when not used or paired with a child contact shows fine. However, when I
assign a child contact to the relay the pins numbers disappear but shows the
sheet reference and location, please help?
Thanks in advance.
KC.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
