Well, AcadE comes with a bunch of script that can be used.
A script file only consists of commands that can be written on AutoCAD's command line "manually". So.. the help-file will be a good starting point for creating your own scripts.
A little tip:
Many commands have both a dialog box and a command line version. If you put a dash (-) in front the command, you get the command line version, which is the one you'd like to use in a script.
For instance.. if you type LAYER on the command line, you get a dialog box. If you type -LAYER, you get the same options, but on the command line (and scriptable)
THL
Trond Hasse LieAutoCAD Electrical and
EPLAN expert
Ctrl Alt ElPlease select "Accept Solution" if this post answers your question. 'Likes' won't hurt either.
