Show only
Search instead for
When I insert a vertical ladder, there is a little bit of the hot and neutral wires sticking above the first rung and below the last rung. Is there a way to automatically make those longer when I insert the ladder?
I do not believe there is, if you notice the vertical wires stick up to the point where another rung could cross. If you need to modify them, simply use ACAD commands to do so.....stretch, offset.....etc. Hope this helps.
It actually goes past the first and last rungs by half the rung spacing. I know that there is a calculation going on in the background, I was wondering if anybody knew where it was located and if I could change it.
I would suggest that you simply start and end your ladder a bit farther away from where you actually want the rungs to be. If you insert rungs, you may have to cut away the top and bottom rungs.
