Hi there,
I am building a schematic from pieces of other similar schematics. The format of the ladder sheet and line references are slightly different. Some have %S%N and others have %S-%N. I have set the Project properties the way I want, copied the Project properties format to each sheet but the reference fomat does not change. I look at the Modify Line Refernce Number dialog box and the Wire Number Format is what I want but the only way I have found to get the format to change is to erase the original reference and re-insert them. Checking the Redo box in the Modify Line Reference Numbers will change the number scheme but does not change the %S%N format. When I re-insert they do the automatic insert with the format I want. Kind of a slow way to do this. Am I missing something or is there a better way to do this?
Any advise is appreciated,
Thank you
Tim
Have you tried the command to revise the ladder.
It should be in the Wires tab under the Ladder group.
Just click and hold on the Ladder command and the additional commands show up after a second or two.
The actual commands available are...
Insert Ladder
Revise Ladder
Renumber Ladder Reference
Convert Ladder
Regards Brad
Brad Coleman, Electrical Draftsman
Thank you for the reply. the Wires>Ladder takes me to the same Modify Line Reference Numbers window. That is where I thought it should work but it does not. It will change the Rung Count, Ref Start, etc. but it will not change the Wire Number Format. At least not any way I have tried yet.
But thank you again for the reply, have a great day.
