Oh I see what you’re talking about.
If you set the crossing wires to Wire Jumps it makes more sense. When you add the connecting dot the wire jump is still there.
Your putting too much work into the wire breaks with the extra wires, trim, stretch.
Try using Break off the Modify drop down.
Start the command, select the wire to break and then click right on the intersection. After that add your connecting dot and it should only give it one wire number.
Stan
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
