AutoCAD Electrical Forum
Is it possible to question
5 REPLIES 5
402 Views, 5 Replies
is there a way in ACAD/E so that when I build a panel schematic/one-line having i.e. relays, breakers, fuses, etc so that when i build an actual panel or subpanel layout all the associated components would automatically be but onto the panel in the correct place and have the correct tagging, labeling, and such
thanks for any help
5 REPLIES 5
if someone could please give me some kind of feedback it would be very appreciated.
drathak
thanks for any help
In a word, no.  It won't automatically place your layout components for you.  How is it supposed to know where they physically go until you tell it?
Now, once you have your schematic done, doing the layout goes pretty fast since you have a list of parts to work from at that point.  It's a matter of picking them from a list and placing them wher you want them.  All the tagging/labeling comes in with the footprint symbols.
As an example, doing things our legacy way, a switchboard panel might have taken me a couple of days to layout and wire up.  With most of that time being adding the wiring.  With ACADE I am able to layout a panel and wire it in less than 30 minutes.  (12 if I already have the centerlines in place.)
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
electricman1
Actually such a site does exit, but A-B PLC hardware only.
www.racklayout.com
dougmcalexander
Panel layout involves many factors. Keeping AC and DC separated as much as possible. Noise immunity. Designing in such a way that the fewest number of wires cross the door hinge. Positioning in a way that uses the least amount of wire. If the software starts taking over these decisions, the designer jobs can be replaced by the lesser skilled. But seriously, layout decisions need to be made by a human with proper training and experience.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
in reply to: drathak
thanks for the advice it helped!
”Boost
