AutoCAD Electrical Forum
interportability Acade 2014 and inventor 2012
2 REPLIES 2
370 Views, 2 Replies
Good Day.
I need to know about how is the best way to produce the conection between the electrical part (component), the respective terminal and the wire in the "Cable and Harness" module of Inventor
toghether with the Autocad Electrical. I'm doing the exportation in .xml between the two programs, but when I assign all the components and the pins, the wire arrive directly at the pins, but I wan't they arrive to an terminal, not directly (some terminal like an terminal ring or terminal spade)
How is the best form so that I can have the terminal and the wire together in only one component? There exist another way so that I can represent the terminals in Inventor with this info also in the ACADE?
The ACADE representation that I have is the following:
The produced Inventor with this ACADE diagram:
An representation of the Inventor that I wich to be produced:
THANKS  !!!
2 REPLIES 2
rhesusminus
One way to achieve this would be to also draw the cable shoe in the electrical schematics, like this:
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
rhesusminus, thanks for this answer it worked well.
”Boost
