IN the Symbol Bilder space work indicate the follow error after I press Symbol audit: "Insertion Point " ErrorNum="1, "Not in line with wire connections", how can I solve this problem?
Solved by rhesusminus. Go to Solution.
The insertion point of the symbols must be somewhere between two connection points to avoid this "error":
That being said... I've done hundereds of symbols with connection points on only one side, getting this "error" a lot. So, if you have connection points on both sides, try to get the insertion point at the correct place. If you only have connection points on one side, or you for some reason can't have the connection points on the same "level", just ignore the "error".
yes another one of those issues that autodesk cant be bothered to adresss
to busy going forward rather than addressing existing problems
