You can use the Multiple Insert. There are 2 variations, select a component
to insert from the menu or select an existing component to copy multiple
times. Then you draw a fence through the wires to insert the components on.
Hope this helps,
Pat Murnen
wrote in message news:6302481@discussion.autodesk.com...
Can anyone help..? just completing a schematic and want to insert multiple
round terminals at "T" connections is there an easy way to multiple copy and
paste/ insert?
