AutoCAD Electrical Forum
inserting multiple connectors terminals
4 REPLIES 4
412 Views, 4 Replies
Can anyone help..? just completing a schematic and want to insert multiple round terminals at "T" connections is there an easy way to multiple copy and paste/ insert?
4 REPLIES 4
You can use the Multiple Insert. There are 2 variations, select a component
to insert from the menu or select an existing component to copy multiple
times. Then you draw a fence through the wires to insert the components on.
Hope this helps,
Pat Murnen
wrote in message news:6302481@discussion.autodesk.com...
paste/ insert?
Hi Pat,
thanks for that.. Yes I did that and the level of success was not great.. most of the inserts requires some wire snipping afterwards so it kind of defeated the objective so whereas to either insert or copy a component singularly it slots in to the wire or crossing neatly multiple inserts/copies didn't! strange hey? or is it just me?
If you can post something that shows what you are doing maybe I can see what
is happening. Or if you want to send a drawing to me directly along with
some instruction on what components you are inserting and what you select,
my direct email is pat.murnen@autodesk.com. There aren't any logged issues
with this feature that I am aware of.
Pat Murnen
wrote in message news:6302537@discussion.autodesk.com...
Hi Pat,
Hi Pat,
Thanks I will send you an email with a sample
”Boost
