Hello All,
I am having an issue inserting a 3 pole fuse block onto a vertical bus. When I insert it it puts the HFU1 block when it should put the VFU1 block on the bus. I can insert a 1 or 2 pole fuse block onto the same vertical bus and it inserts the vertical block properly.
Any ideas where to look???
Dennis
