These should have been installed with whatever library was selected at
installation. The default location would be \Program Files\Autodesk\AcadE
200#\Libs\{library folder}. If they exist in the folder then you just need
to make sure the project has this path as one of the library search paths.
If they do not exist then you might try a repair on the software which is
done under the Windows Control Panel, Add Remove Programs.
If this doesn't work I can see if there is a way to reinstall just a
library. I don't think the symbols have changed much over releases so if you
have any from a previous release they can be used.
Pat Murnen
wrote in message news:5873929@discussion.autodesk.com...
When I am using the Symbol Builder (ACE2008) and attempt to add Wire
Connections, the grid (9 squares) are empty. When I click on a square and,
depending on which terminal style I have selected, I get "File Not Found
:bbxxx.dwg" error and goes through the search path looking for the file.
bb021.dwg, bb121.dwg and so on are the files it is looking for.
The problem is that I do not have the files it is looking for anywhere that
I can find. Have gone back and looked on disks from ACE2007 and 2008 to no
avail. Where can I get these files from or am I overlooking something?
