AutoCAD Electrical General Discussion
Member
backcountryjame
Message 1 of 3 (136 Views)
insert wbcircuit problem.
136 Views, 2 Replies
07-03-2012 11:39 AM
Everytime i try to insert a WBCIRCUIT under the schematic tab or with the command "AEWBCIRCUIT" usually a dialog box pops up and I can browse all my saved circuits. This is what the "Help" feature also tells me to do (F1). But everytime I use it now, it prompts me for the block name. Simular to when I create a block. This is what the command line gives me.
Command: aewbcircuit
Insert WBlocked Circuit
_.UNDO Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: _MARK
Command: _.UNDO Current settings: Auto = On, Control = All, Combine = Yes,
Layer = Yes
<1>: _BEGIN
Command:
"Block name:"
Maybe I have a setting wrong but I can't seem to figure it out. On one of our other Steats it works and the Command promt looks like this when its working:
WD_M insert: C:\Users\Public\Documents\Autodesk\Acade 2011\Libs\jic125\WD_M.dwg
<1>: _MARK
Layer = Yes
<1>: _BEGIN
Although, my seat doesn't indicate
"WD_M insert: C:\Users\Public\Documents\Autodesk\Acade 2011\Libs\jic125\WD_M.dwg"
after inputing the command.
Does anyone have an idea of what to do?
Thanks!
James
Distinguished Contributor
Tee.Dee
Message 2 of 3 (124 Views)
Re: insert wbcircuit problem.
07-04-2012 07:42 PM in reply to: backcountryjame
You could try this:
 In the command line type in FILEDIA then press enter then enter a value of 1 and try the the AEWBCURCUIT command again.
Let us know if that works.
Tim
Member
backcountryjame
Message 3 of 3 (111 Views)
07-05-2012 08:26 AM in reply to: backcountryjame
works great - i really appriciate the help.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
