AutoCAD Electrical Forum
insert wbcircuit problem.
2 REPLIES 2
320 Views, 2 Replies
Everytime i try to insert a WBCIRCUIT under the schematic tab or with the command "AEWBCIRCUIT" usually a dialog box pops up and I can browse all my saved circuits. This is what the "Help" feature also tells me to do (F1). But everytime I use it now, it prompts me for the block name. Simular to when I create a block. This is what the command line gives me.
Command: aewbcircuit
Insert WBlocked Circuit
_.UNDO Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: _MARK
Command: _.UNDO Current settings: Auto = On, Control = All, Combine = Yes,
Layer = Yes
<1>: _BEGIN
Command:
"Block name:"
Maybe I have a setting wrong but I can't seem to figure it out. On one of our other Steats it works and the Command promt looks like this when its working:
WD_M insert: C:\Users\Public\Documents\Autodesk\Acade 2011\Libs\jic125\WD_M.dwg
<1>: _MARK
Layer = Yes
<1>: _BEGIN
Although, my seat doesn't indicate
"WD_M insert: C:\Users\Public\Documents\Autodesk\Acade 2011\Libs\jic125\WD_M.dwg"
after inputing the command.
Does anyone have an idea of what to do?
Thanks!
James
2 REPLIES 2
Tee.Dee
You could try this:
 In the command line type in FILEDIA then press enter then enter a value of 1 and try the the AEWBCURCUIT command again.
Let us know if that works.
Tim
works great - i really appriciate the help.
”Boost
